Level One USB BT + 6600 + any OS
1 replies · 1,874 views · Started 29 June 2004
😮 Maybe you talked about this before, but i didn't found the topic. I installed the dongle using attached driver (vidcom ver: 1.4.2.10). Maybe it will help so i am atthaching the install ini file:
SuppressWrongOS=Y
ScriptDriven=0
ScriptVer=1.0.0.1
DotNetOptionalInstallIfSilent=N
OnUpgrade=1
RequireExactLangMatch=0404,0804
Product=Bluetooth Software
PackageName=BTW.msi
MsiVersion=2.0.2600.0
EnableLangDlg=N
DoMaintenance=Y
ProductCode={FE90E9E7-A158-4687-8853-DF677A939A61}
ProductVersion=1.4.2.10
SuppressReboot=Y
PackageCode={A8407146-3B78-4707-BD29-B2663F841BCB}
Looks like the dongle is using same driver as MSI. I was able to install the driver and pair the PC and 6600 without any problem. When i clicked on port connection in BT neighbourhood windows reported an error that my phone dropped the connection. I got the same result on WinME and WIN2k. I am not using any firewall, just norton antivirus. I cant seem to enable the virtual com. port between the devices.
Any sudgestions???
DawGuru
dawguru wrote:😮 Maybe you talked about this before, but i didn't found the topic. I installed the dongle using attached driver (vidcom ver: 1.4.2.10). Maybe it will help so i am atthaching the install ini file:
SuppressWrongOS=Y
ScriptDriven=0
ScriptVer=1.0.0.1
OnUpgrade=1
PackageName=BTW.msi
EnableLangDlg=N
DoMaintenance=Y
SuppressReboot=Y
Any sudgestions???
DawGuru
Yeah, get the nokia pc suite for th 6600 and install that. You didn't exactly say which dongle you installed so it doesn't really matter if vidcom/ Widcomm is using the same drivers as msi since the hardware may or may not support the entire feature set or support it in the right way. I set up my bt serial port then installed the pc suite, connected the sp w/ the bluetooth tray icon then clicked through the connections in mrouter to get it right (probably did some things in between too) your milage may vary.
