Softcam and MSN
7 replies · 4,495 views · Started 29 June 2004
Im trying to get softcam and remotes60 to work as a webcam via msn 6.2 but i cannot get it to work. ive read somewhere it works with msn and not yahoo.
all i get in the webcam screen on msn is the luminositi logo?? what am i doing wrong?
TIA
cliveuk wrote:Im trying to get softcam and remotes60 to work as a webcam via msn 6.2 but i cannot get it to work. ive read somewhere it works with msn and not yahoo.
TIA
Softcam and Remote60 will work with Yahoo and MSN, I know because I use them myself.
You need to set Softcam to Live rather than Stored, then use Remote60 to display your camera feed (preferbly using the "Camera Preview" option, and not just a straight feed from the phones display, otherwise when the cameras screensaver comes on, the camera feed will also show it.
You can do the above when a webcam session has been initiated with a user and Softcam has loaded via the camcorder icon in your tray.
Hope this helps.
Andy.
I'm doing everything right and doesn't matter where I move the capturing frame (the golden one) it shows black in either MSN or softcam's own preview window. What I am doing wrong?
can16358p wrote:I'm doing everything right and doesn't matter where I move the capturing frame (the golden one) it shows black in either MSN or softcam's own preview window. What I am doing wrong?
hı I fırst of all soft cam captures the screen so after launching camera option in remotes60 bring the frame over srceen where the video is running it very easy
kolay gelsin
drhy wrote:hı I fırst of all soft cam captures the screen so after launching camera option in remotes60 bring the frame over srceen where the video is running it very easy
kolay gelsin
Nope, its not the problem.
The Softcam doesn't see anything. It is only black either in the preview window or webcam at MSN MEssenger when I start.
Do you have any other video capture devices? i.e. a webcam? or are you running any third party desktop customisation programs? if so try disabiling them.
Hello 😊
I have just downloaded Remote S60 and SoftCam 1.5, and it worked from the very start perfectly. Also with MSN 6.2 which does NOT accept my original webcam (Keter Eye-On).
So i have a "real" webcam AND SoftCam and it works very well.
However what bothers me is the "camera on standby" after a minute or so. The phone is a 6600. Is there a way to keep the camera active?
Any help is appreciated 😊
Your Thanh
PS it rocks - because you can wander around in the room and show your webcam partner stuff... beats a (cable-bound) "real" webcam!
Thanh-BKK wrote:Hello 😊
Your Thanh
