Audio sync problem with smartmovie
1 replies · 8,275 views · Started 29 June 2004
I am know starting to get my head around converting movie files for use with smartmovie and 6600. I am currently usinf gnot first of all to convert vob's to xvid. When this file is played back using media player the audio sync is spot on through out the movie.
The proble comes when I use smartmovie to compress the file, when I play this file back in media player the audio is out of sync. My settings for smartmovie are listed below:
Video Settings:
Landscape
Reduce frames
Xvid encoder
Bitrate = 80kbps
Audio Settings:
Enable - yes
Force mono - yes
Frequency - 16000Hz
Bitrate = 80kbps
Lame Mp3 codec
Volume boost 150%
Any help would be greatly appriciated, as apart from this minor problem the video quality is superb.
Many Thanks 😮
in the smartmovie player on ur phone......go to options....then down the bottom u can put a delay for when the sound comes into play....be it 0.5 seconds or what ever....if u tweak around this option a little bit...u r sure to find a setting that will match the sound with the video...........its a all a bit of trial and error really
