Keypad getting stuck?
9 replies · 2,170 views · Started 30 June 2004
Hi all, just got my N-gage QD a week back.
I've noticed that sometimes after playing some games, the right side of the number pad gets stuck. In particular the 3 and 9 key.
Any one has encountered this problem before?
How do I open up my QD?
Thanks!
andretan wrote:Hi all, just got my N-gage QD a week back.
Thanks!
WOAH sounds like u got it bad, u'll wanna bring it to the service centre and get it done up. No i don't have that problem.
For wat i've been tinkering around, i don't recommend u open it coz there doesn't seem to be any supposed proper way to open it...
If you do open the unit it will void your warranty.
I would strongly recomend you do not try to remove the cover yourself!!
But I thought I read somewhere that the cover could be replaced?
I think I read it in HowardChui.com -- in the N-Gage QD review..
andretan wrote:But I thought I read somewhere that the cover could be replaced?
Well u see the QD unfortunately doesn't have the Xpress-On cover concept we've all gotten so used to in Nokia phones... Of course, u CAN change the covers, since i do believe i've seen 2 new covers on Gamestop.com if i'm not wrong, though i seriously don't think its a DIY kind of replacement.
Dr@n|xX wrote:Well u see the QD unfortunately doesn't have the Xpress-On cover concept we've all gotten so used to in Nokia phones... Of course, u CAN change the covers, since i do believe i've seen 2 new covers on Gamestop.com if i'm not wrong, though i seriously don't think its a DIY kind of replacement.
Hi 😊
Which part of Sg ya from? :P
I stay around AMK/YCK.
andretan wrote:Hi 😊
Yo 'sup, i stay the Bukit Timah area 😊
I have the exact same problem! The 3 and 9 keys get stuck most of the time making a strange clicking noise, it's only started to happen now though and I've had the QD for almost a month.
tomrudderham wrote:I have the exact same problem! The 3 and 9 keys get stuck most of the time making a strange clicking noise, it's only started to happen now though and I've had the QD for almost a month.
Geez. I just had mine for over 2 weeks!
