transfer themes from 6600 to 7610>?
2 replies · 2,646 views · Started 30 June 2004
Has any figured out how to do this?
LOOPSTER
Badges, we don need no stinkin badges..!! :icon14: [FONT=Arial Black]undefined[/FONT]undefinedundefined
I have used 6600 themes on a 7610, the only thing is that there are a few icons, which don�t change.
There is a new version of Theme Studio available which not only has support for 7610... It also officially runs on XP.
:icon14:
If your question is about sending themes from phone to phone, this is only possible (as far as im aware) if you have the *.sis file stored on the MMC and have a 3rd party filemanager installed. Then just simply send the file via Bluetooth.
I tried sending a SIS and a MIDI file, however ... it always says "Unable to send copyrighted information"
If you're using FExplorer for example, rename the file from theme.sis to theme.sas or something. Then send. Once received, rename it back to *.sis again
Hope that helps 😊
