"Installer" flakes on installing some apps
3 replies · 2,156 views · Started 30 June 2004
I'm having this problem installing some applications: the "Installer" program starts up and then immediately quits without instralling anything. No error messages or anything, Installer just quits. I've installed other applications without a problem.
I'm having this problem with AppMan, FileMan and IM+, which is pretty frustrating since they're all great applications.
What gives?
davel-jonez wrote:I'm having this problem installing some applications: the "Installer" program starts up and then immediately quits without instralling anything. No error messages or anything, Installer just quits. I've installed other applications without a problem.
What gives?
I am having the same issues with my 6600. Some apps install fine and others won't install at all. Anybody out there have any ideas or suggestions for us?
I have been having the same problems with the Handy series from Epoch. Still no solution as to why 😞
I think I found out what is going on. The programs are not localized for US. I was having the same problem with a shopping list program from Mobipaq.com. The developer was great to work with and we figured out that his program was not localised for english. He made a few changes and it installed and works great!
So if you are having a problem an app not installing, contact the developer and let them know you need it localized for english (or US phones).
