Full format code? other then *#7370#
3 replies · 112,552 views · Started 01 July 2004
anyone those any full format code other then *#7370#
call + * + 3 dont works too
k wrote:anyone those any full format code other then *#7370#
No others. Both work on my 7610. For the green/talk/call + * + 3 you need to have the phone powered off, then these keys pressed down and then simultaneously power it on. With only two hands it isn't easy on that model. 😉
thanks for your reply N/A, but i try green/talk/call + * + 3 , it dont work in 7610...
welll... maybe firmware issue..
thanks N/A
What firmware do you have? I had the v4.0421.4ch ... and the Green * 3 (three-key format) works on the 7610. You have to hold onto these three keys while the phone is starting up. Don't let go until you see the word "Formatting ..."
Hope that helps!
