Startup problem, 6600.
3 replies · 1,965 views · Started 01 July 2004
First, sorry for my Engish.....
When i try to start up my 6600, "NOKIA" comes and goes 3-4 times. Then shuts off again. It started when I was sending a SMS to several peopel.
Is there anything I can do? Ore do i have to send it to the shop?
I have tryed taking out the battery and MMS. But it won't work... 😡
drumdude wrote:First, sorry for my Engish.....
First I'd wait a day to make sure you don't have a ton of sms incoming and spamming the phone or outgoing in a queue (message validity should take card of this). Second, call you service provider. Third, if you have a different mmc try that in the phone. Finally (provided you have a backup of your data and your contacts you can do the green * 3 format. This will erase EVERYTHING on your phone, then reload the firmware from the rom. Make sure your battery is fully charged as you have to do this when the unit is unplugged). I'd hold off on the last one until everything else is exhausted (including turning it on where you know you can't have service and where you know you definately do.)
Dont stuff up your phone with resets just take it to your nearest cellphone care center, theyll know what to do.
JasonT wrote:First I'd wait a day to make sure you don't have a ton of sms incoming and spamming the phone or outgoing in a queue (message validity should take card of this). Second, call you service provider. Third, if you have a different mmc try that in the phone. Finally (provided you have a backup of your data and your contacts you can do the green * 3 format. This will erase EVERYTHING on your phone, then reload the firmware from the rom. Make sure your battery is fully charged as you have to do this when the unit is unplugged). I'd hold off on the last one until everything else is exhausted (including turning it on where you know you can't have service and where you know you definately do.)
