6600 divert auto on hellllpp!!!!!
3 replies · 4,212 views · Started 01 July 2004
my 6600 has a prob, the divert gets switched on automatically when i restart the device, doesnt matter how many times i deactivate it..help anyone any other similiar experiences as this, and dont tell me reformat ......
divert ??, is it some app, u should try safe mode (hold pen button and turn phone on, hold till pin code entry appears), this will prevent any app to autostart
i have a similar problem.
when even my phone restart, the divert sign will show.
But when i check status divert is not active. And then the sign disappear.
the sign is quite irriating there...
anyone can help?
jobocrawe wrote:my 6600 has a prob, the divert gets switched on automatically when i restart the device, doesnt matter how many times i deactivate it..help anyone any other similiar experiences as this, and dont tell me reformat ......
just swich off your 6600 and press the green(call) button +(*) and 3 and swich on your 6600 then your mobile going in to formatt mode... and the you will be all right ..... ok
