hi I am using the freeware autolock program called "jjkeylock" which i downloaded from this website... had a problem using it....
even when I disable the software (by setting "Enabled" to "NO"😉 in its options menu, it still locks my keypad after a few seconds... what should I do? is there any other way to disable it temporarily??
--thanks
