Hi to everybody!
I have a question for you!
Will my 7650 support themes if I copy some files from a 6600 on my phone with the eFileManager application by Psiloc? :?
Do you know wich files I have to copy? :?
Thank you in advice!
If only I could get 6600's themes...
No, there is no way you can make 6600 themes work on a 7650. You can buy Smart Launcher and get almost a similar effect with its skins (though, there aren't that many Smart Launcher skins available): http://www.allaboutsymbian.com/shop/
kylery wrote:Hi to everybody!
try nokia theme studio for series 40...
or themerizer. but im not quite sure if its already available.... :rock: :rock: :itsme:
