Help Please!!!
2 replies · 1,192 views · Started 02 July 2004
Hi peeps
My nokia 6600 Will not connect to PC Suite anymore, i have even formatted the computer and it still wont connect. It connects to the computer ok and i can transfer files with the IR software, but like i said i cannot connect to Nokia PC SUITE, Any ideas please?
Regards
Bashy
If you're using bluetooth try this (if you aren't some of it might be helpful).
Go to your bluetooth places and delete all the uneccessary services for your phone first (then recreate the serial port, although I'm not sure that's necessary). Try restarting cuz windowz sux. Then like you were doing click the bluetooth icon and quickconnect to your nokia 6600. Then try mrouter and click and unclick all the ports. If that doesn't work you may want to kill off some more bluetooth places (are you really using fax, etc.) Also turn off anything set to autostart and MAKE sure you aren't running or have rebooted since you ran directx diagnose. Ignore the messages about the comm port NUMBERS (if it says your phone connected on 0 and all devices need to use that comm port it doesn't mean anything when it comes to mrouter. Turn your phone on and toggle bluetooth and ir.
Hope that helps (you can recreate all the places) last thing you want to do is a full re-pair of your device.
On more..make sure your phone isn't communicating w/ any other device while you are trying to connect to the pc suite.
