Bluetooth help pleease
5 replies · 1,456 views · Started 03 July 2004
hi .. i have the n-gage qd. i bought a usb bluetooth dongle (made by windigo systems) and i cant fingure out how to use the nokia pcsuite. when i click on the "Connection" button on the taskbar it says all the COM ports are disconnected. when i click change devices it cant find any. i really dont have a clue what to do so could someone please help me.
thanks in advance
tom
hi is it the wavelinker if so i've got one its hard getting it working but you have to first find the ngage with the XTNDConnect Blue Manager then open up the mRouter and tick COM4 and it seems to connect after awhile
The basic idea (details depend on which/whose Bluetooth software you have on the PC):
1. Use the Bluetooth software on the PC to create a "virtual" serial port (so called "COM" port).
2. Pair the PC with the phone.
3. Configure PC Suite (mRouter/Connection Manager) to use Bluetooth and the virtual COM port you've created.
4. Launch PC Suite.
