Series06productid-FIX?
6 replies · 2,403 views · Started 04 July 2004
when i tried to install the progs and games of Series60 nokia into my motorola A925 ,it required me to install the prog "Series06productid" first, so plz, anyone know this, plz let me know how to fix this problem. Thanks
The Motorola is based on the UIQ user interface like the Sony Ericsson P800/P900, not Series 60.
Series 60 programs will not run on UIQ, but you could try P800/P900 programs instead.
You can also contact the developers of the Series 60 programs you like, and ask if they have an UIQ version available or planned.
N/A wrote:The Motorola is based on the UIQ user interface like the Sony Ericsson P800/P900, not Series 60.
so can I install the prog of P800/900 on my A925 ?and if i want, how could I do that? do I need to install anything?
Most P800/900 apps will work on the A925! You don't need anything else, you can just install the *.sis file
Delta737 wrote:Most P800/900 apps will work on the A925! You don't need anything else, you can just install the *.sis file
dont forget the p800 product ID.sis file !!! and stay away from games rquiring appforge booster !!!
-->plz tell me what to do with this problem, I'm a newbie :redface:
nguyenldk wrote:-->plz tell me what to do with this problem, I'm a newbie :redface:
being a newbie does'nt excuse you from using the search function either here or at one of the othe forum's you have recntly registered at !!!
