!!problem, removed a folder!!
1 replies · 2,076 views · Started 04 July 2004
hi
i removed a folder from my phone by mistake with FeExplorer.
the folder was located in c:\system\apps\
name of the folder was: autolock
what is it for, could someone maybe copy it from their own phone and mail a zip file to me.
//Nicke
It was a program you installed on your phone. Must be an app which locks your phone automatically in a specified time.
It doesn't matter. If you deleted it, the program would be "gone" and the icon won't be in the Main Menu.
Try not to delete those folders. Uninstall the programs using Manager instead 😊
