Use tcp/ip over bluetooth as accesspoint?
3 replies · 3,988 views · Started 05 July 2004
Hi there.
just got my new toy connected to my linux box via bluetooth. Can transfer files and mount the sx1's filesystem to the pc.
I also am able to establish a ppp connection between the sx1 and the pc. The sx1 accepts the ip and I can ping it. Unfortunately that's about the only thing I can do with the tcp/ip connection. Opera and putty on the phone both bring up the accesspoint selection when I hit "connect" or try to send data to the internet. So it seems I have to tell the sx1 to use the existing connection and to use the linux box a default gateway.
Anyone out there who has succeeded in doing this?
Thanks,
Torsten
where do i find or change the passcode of the bluetooth device in linux? it asks for it when i try to pair in my 6600
unknown wrote:where do i find or change the passcode of the bluetooth device in linux? it asks for it when i try to pair in my 6600
Clear text entry in /etc/bluetooth/pin
(It's the only entry, only the number on the first line)
