Motorola a920 Desktop suit
2 replies · 4,425 views · Started 06 July 2004
Where can I install Motorola A920 Desktop Suit Programme from the internet? P.S: I do not want to install Motorola A925 Desktop Suit programme. I tried to install but it did not work
If you havent had your A920 upgraded to A925 s/ware yet (with the bluetooth and s/ware unlocked) I strongly recommend you get it done, the original A920 is useless and does not work properly !!! it crashes continuously and drops calls all the time, also it has been restricted by "3" to not let you install any software at all !! unless you download it from "3" themselves !!! if you are still a "3" customer you can get it done for free by sending it to them !!!
they way forward is to upgrade your phone not downgrade you PC suite !!!
PS do you know a JW called Lance
[QUOTE=Ice coffee]If you havent had your A920 upgraded to A925 s/ware yet (with the bluetooth and s/ware unlocked) I strongly recommend you get it done, the original A920 is useless and does not work properly !!! it crashes continuously and drops calls all the time, also it has been restricted by "3" to not let you install any software at all !! unless you download it from "3" themselves !!! if you are still a "3" customer you can get it done for free by sending it to them !!!
[Motorola A920]
Hi - How do I upgrade the s/ware... and where do I go to do it?
...does anyone know how to save pictures from email on the A920?...If so please let me know. When I goto [download] it only shows the picture on the screen and does not save it. - Thanks Matt - [email][email protected][/email]
