MMC Problem
1 replies · 6,794 views · Started 06 July 2004
hi.
I put some bad sofware on my 6600 mmc and now I can't uninstall those programs (it gives me a "file corupted" error), and also I can't access my mmc since then (with any file explorer) - it just doesn't open the mmc drive.
But all my games and the other software on the mmc works just fine, and I cand install other applications on it; I just can't access it or uninstall the applications that I think caused this errors.
Do you know how i can fix my mmc (some soft or anything) ? I think about formating the mmc, but i need a pc application that can backup my mmc data on my computer; PC Suite doesn't work for me, because it doesn't find the bluetooth port (on connection properties it only shows me an infrared port - witch i don't have). So do you know any other backup soft ?
Thanks, and I'm sorry for my bad english.
Hi, i think that the problem is that files that u wanna delete are setted as "archives" or "only read" so u can't delete by your phone but u have to delete theme by your pc (put your mmc in a memory read for pc)
