BT profiles Headset or Handsfree?
2 replies · 1,742 views · Started 08 July 2004
Which one do we have? Am I correct in saying that it is the headset one?
Which one has more functionality? Are we losing out?
What functions are on each?
As you can guess I am looking to buy an earpiece.
All Nokia phones currently supports the Bluetooth Handsfree profile only.
Most, if not all, current Bluetooth headsets support both the Bluetooth Handsfree profile and Bluetooth Headset profile. (Some of the first ones marketed only supported the Bluetooth Headset profile, and those will not work with Nokia phones.)
All that support at least the Bluetooth Handsfree profile should work.
Thank you for you answer.
But do we loose out on things like last number redial and call transfer, conference calling, that are on headsets like the Jabra and Motorola?
