hi guys
i have a couple of questions about updating firmware on my orange 6600.
- basically i want to do this because i don't get sounds with games like colin mcrae rally 04 and rainbow six 3, both java games. i'm hoping that the firmware will fix this?
- do carphone wharehouse do this for free, they're my nearest official nokia service centre. i don't know whether i am entitled to a free firmware upgrade or not?
- everything i want to keep is on my mmc which i will remove for privacy reasons, will i be able to put it back in and have everything work as normal again?
thanks people, hope you can help!
r0undeye wrote:hi guysi have a couple of questions about updating firmware on my orange 6600.
Q1: Some java games do not play sound on 6600 but if you send the same file to an n-gage it will work perfectly,so a firmware upgrade may not be answer.
Q2: Usually you would get a free upgrade if you are in the first year.
Q3:Yes.
thanks elton, i'll be down there at the weekend to see what they can do 😊
a good way to make sure to get the newest firmware is to ask specifically for the one yuo want. i did the same w/ a orange 6600 and got the generic 4.09.1 took all the orange software off, but its the newest upgrade and is alot better than oranges newest software
