Hi, I recently downloaded some sample Series 60 applications by Nokia, more specifically the "Elements" project. Anyway, i'm running the app on the Metroworks Codewarrior emulator and it tosses an error when trying to read from a file.
The file is defined in the elementsengine.cpp by a string literal
_LIT(KMetalsFileName, "C:\\Symbian\\metals.csv"😉
and I have double checked that this is the correct pathname, but it still hangs when it trys to read the file from that location. Am I wrong to assume the path should have two backslashes? I tried one backslash and ran the debugger and the value for the literal removed the single backslash.
So my question is, has anyone ran this sample application with success? I'm trying to learn how to read/write to files using Symbian with this application, so any help would be great. One backslash, or two? Thanks in advance!
