Can you use the USB cable for pc suite?
1 replies · 2,445 views · Started 09 July 2004
Can you use the included usb cable for the pc suite software, or do you have to use bluetooth?
(Nokia N-gage original)
Noah wrote:Can you use the included usb cable for the pc suite software, or do you have to use bluetooth?
no. u must have BT in order to use PC suite.
when u plug the n-gage into the PC with the USB cable your MMC will show up in My Computer
