Just got an n-gage so I thought Id try and run some of the java games I wrote got my SL55 on it.
I copied the .jar files to it and tried to open them in FEexplorer. It says it is 'installing' then immediately after says it is 'removing' and gives me a
'! Applications: System Error'
Anyone know whats going on?
FYI this is the guide to the sorta of app Im trying to run
http://www.gamedev.net/reference/programming/features/j2me1/page3.asp
I think that this specific java app doesn't run on youre N-gage.
It is a very simple app that is designed for any java phone. The guide that I mentioned in the first post even specifically mentions the ngage as one of the phones it should work on.
I wrote a very simple MIDLet for my Nokia 3650 but while installing, I am seeing the same error - "! Applications: System Error"
any ideas what would be causing it.
I am trying to install the MIDlet from the PCSuite For Nokia3650 S\w.
Any ideas to resolve this problem ?
thanks in advance,
Mihir
Vapour wrote:Just got an n-gage so I thought Id try and run some of the java games I wrote got my SL55 on it.I copied the .jar files to it and tried to open them in FEexplorer. It says it is 'installing' then immediately after says it is 'removing' and gives me a
All your problems sound familiar, check the forum, i think its been mentioned before.
I found that I was getting the Error because my phone - Nokia 3650 didnt support MIDP2.0. I had downloaded the Wireless ToolKit version 2.0 that supports MIDP 2.0 and then built my Midlet using the toolkit.
However, I found that, currently, no phones in the United States support MIDP 2.0
I then downloaded WTK version 1.0.4 that supports MIDP 1.0, and built my MIDLet. and it ran smoothly .... without a glitch ...
I hope this helps someone who stumbles across a similar problem .... Also, for any first timer to writing MIDLets for your phone, this article will be the most helpful:
http://altisimo.com/publications/j2me-hello/
cheers,
Mihir
mihirk wrote:I wrote a very simple MIDLet for my Nokia 3650 but while installing, I am seeing the same error - "! Applications: System Error"
any ideas what would be causing it.I am trying to install the MIDlet from the PCSuite For Nokia3650 S\w.
thanks in advance,
Mihir
