Theme made but can't get a .sis file
4 replies · 4,557 views · Started 11 July 2004
I really need your help:
I've lost a few (many!) hours building a theme. Once it was done I tried to convert it to .sis. Which, according to Series 60 Theme Studio, was done succesfuly. The problem is that the .sis file created has 0 bytes. I mean, when I put it in my phone, it goes to the default theme. I already tried to unisnstall a reinstall the prog. but it remains the same. Early today, again, I tried to buid the same theme from scratch, using the images from the previous. When I was in the middle I saved it and it was ok. But in the end, the same thing happened: "sis file converted"... and no .sis file with what I had been doing exists.
I'd really apreciate your help Please.
Is there any other program where I can build themes for my 6600?
TKS!!
Cortex wrote:I really need your help:
TKS!!
You most likely had a "bmconv error" which means that the .sis file will be created but incorrectly .
The most likely cause is with the "List hightlight" so edit the theme you made and change the "list highlight" to default in the components browser,then create the .sis and all should be well.
For more info on this Search the themes forum for "bmconv error". 😃
elton wrote:You most likely had a "bmconv error" which means that the .sis file will be created but incorrectly .
This really was the cause.... I'm amazed. Thanks a LOT!!! :icon14:
What a bug :icon13: !!!
