pinboard slice (theme studio 1.14)
4 replies · 3,682 views · Started 12 July 2004
hi all,
below is the image of which im having problem with.
(the white pinboard slice - qsn_bg_slice_pinb_image1.bmp)
i have tried replacing it with the image i want & clearing but still doesnt get it change.
i also tried to del the image off the folder then create sis but it still turn out white.
does anyone know how to replace it the correct way?
has the theme filesize anything to do with it? (d2.sis currently 250kb)
btw im using theme studio 1.14
below is the image of my incomplete d2 theme.
thanks in advanced.
The pinboard slice image will only be accepted if it is one solid colour,which is a ridiculous bug i know,and one that took me a while to work out but i think if you set the the colour to black in this theme it will definatley look better than white :icon14:
elton wrote:The pinboard slice image will only be accepted if it is one solid colour,which is a ridiculous bug i know,and one that took me a while to work out but i think if you set the the colour to black in this theme it will definatley look better than white :icon14:
i will try it out.. thanks a lot! 😃
I've tried it elton, and it didn't work.. i replace it with black color, the dimension is 176 x 4 right? the result is still a white thin line... *sob*
hi guys..
i have rectified the problem on both 6600 & 7610..
it only appears white on 6600.. so i guess its either fw bug or studio bug..
