I know that I can set my incoming folder on mmc, but is there a way to import my old phone messages to the new mmc messages folder? :?
I hope I was clear :tongue:
6600: sms from phone to mmc memory?
What about seting the inbox on phone memory and then back on MMC?!
Josie wrote:I know that I can set my incoming folder on mmc, but is there a way to import my old phone messages to the new mmc messages folder? :?
When you change the memory in use setting, it usually asks if you want to copy the messages over,if not then use a file explorer and just copy and paste the messages from C:/system/mail to D:/system/mail or vise versa.
There is a probelm!
Infact If you copy all files from c:\system\mail to e:\system\mail and you set MMC as memory for incoming messages, you can' t see the messages you have befor on phone memory, cause there is an index files in c:\system\mail which have an immage of every message! When you copy all in e:\ the message are in e:\ but when you open inbox messages you can't see them!
I've got the same problem!
I don't if there is a softwere which transfer messages
I think if you backup the phone memory on yur MMC all yur messages are copied to the MMC arent they?
