3620 with att any good?
3 replies · 2,260 views · Started 12 July 2004
where i live we have tmobile and at&t with gsm....so i either have to choose at&t with the 3620 or tmobile with the 3660.... i was wondering what u guys thought about what 1 i shoud choose.. 😃 ... at&t gives me better plans... but ive heard really good things about tmobile.... 😎
thanks
loki
loki2043 wrote:where i live we have tmobile and at&t with gsm....so i either have to choose at&t with the 3620 or tmobile with the 3660.... i was wondering what u guys thought about what 1 i shoud choose.. 😃 ... at&t gives me better plans... but ive heard really good things about tmobile.... 😎
thanks
loki
I use ATT and love it, and plans are better. BUT, be aware that no matter which you choose, you can not access AOL due to the new WAP version on this pone. Not worked out yet, so opt for less MMode and save if you do not need AOL on your phone.
I have t-mobile and love it. Tech support is second to none and the rate plan I have seems better than most at an awsome price. Good luck.
With the 3660 you can go overseas and still use your phone. The 3620 has1900 and 850mhz and that'll only benefit you if you use Cingular or AT&T.
