I have a question about the contact list. Is there a way to import a text file to my contact list? I have a list of about 250 numbers/names from my old phone (720c) that I save as a csv. I looked at the Nokia PCsuite and it appears to not support this. I also searched the forums and found a reference to "Oxygen" this would seem to be what I am looking for and was wondering if anyone had any comments.
Thanks in advance
/bit
Contact List
bitsiphon wrote:I have a question about the contact list. Is there a way to import a text file to my contact list? I have a list of about 250 numbers/names from my old phone (720c) that I save as a csv. I looked at the Nokia PCsuite and it appears to not support this. I also searched the forums and found a reference to "Oxygen" this would seem to be what I am looking for and was wondering if anyone had any comments.
Thanks in advance
/bit
Contacts Manager uses the same format (.csv) for exporting Contacts list, maybe u can use it to import ur list to your phone. Tell me if it works.
