i have tried to use mbmwizard to extact themes but i get a "Not a valid archive" error when i try to 'Open' or 'Import' the mbm file into mbmwizard . is there anything i am missing out on?
i basically want to save the wallpaper of a particular theme separately, is there any other way of doing this? I have looked using FExplorer and cannot seem to find the wallpaper file by itself, i am guessing it is part of the mbm package?
First off you would need to disassemble the *.sis file to get the *.mbm file. Once you have the *.mbm then open it in the mbmwizard.
Hi. Have the same problem as vprasad007. Have already extracted the mbm file from the sis file and opening them with mbmwizard (have also tried Theme Editor 6600) but all I get is "Not a valid archive". Have tried the open and import options already.
hello! can anyone tell me where can i get mbmwizard? i tried the sites given but its not working.
I get the same problem too. "Not a valid archive" when I try to Open/Import the extracted mbm file in MBMWizard.
I also tried extracting the mbm with WindowsCommander (or TotalCommander) instead of UnSIS and the same message appeared in MBMWizard.
me to I have the same problem i have extract the mbm file with the total commander and know i ca't open the mbm file. NOT A VALID ARCHIVE. wat's missing?
If you had 'searched' or even looked down the page a bit you would have found this thread.
