I have this really big problem with the program. I can not transfer mp3 files to the phone. If i try to send any other type of file it works,butwhen i try to send a mp3 file it jams to cpu - 100%usage from econnect.exe (i think) and there is nothing to do but end the program. considering the fact that after i reinstalled the program it still won't work, what are programs for file transfering (to a specified folder on the disk) are there on the web? I could still transfer them via the program from windows but it doesn't always work and it sends them in the inbox, from there i have to copy them, then delete the msg. It is more trouble than pleasure. So, can u help me?
Nokia 3660 and Pc suite.
myx wrote:I have this really big problem with the program. I can not transfer mp3 files to the phone. If i try to send any other type of file it works,butwhen i try to send a mp3 file it jams to cpu - 100%usage from econnect.exe (i think) and there is nothing to do but end the program. considering the fact that after i reinstalled the program it still won't work, what are programs for file transfering (to a specified folder on the disk) are there on the web? I could still transfer them via the program from windows but it doesn't always work and it sends them in the inbox, from there i have to copy them, then delete the msg. It is more trouble than pleasure. So, can u help me?
What are u using, Bluetooth or infrared? If u use bluetooth just right click on the file and send it through the bluetooth option command.
I use irda and when i think it is the same way as bluetooth just the connection is different. I uninstalled pc suite today, maybe i'll reinstall it these days but besides the fact it takes up a lot of memory on my pc, it doesn't do much. Aren't there other programs like the pc suite?
when you send files to 3650 via Pc Suite that are videos, or audio, the PC Suite automactly converts them to nokia's format - wav for audio files (mp3,..) and 3gp for video files. You should turn that option off in PC suite. Go in Control Panel> File Converters and turn that off. I think that should work😊
I forgot to say in my first post the i did not install the file converters just because of that. So any other ideas?
