Nokia 6620
7 replies · 3,208 views · Started 13 July 2004
ive been browsing the forum for a while now and have seen hardly any referances t the 6620 and i cant find it on the nokia website
im presuming that it is a 6600 updatelike the 7250 is to the 7210 if so what advantages does it have over the 6600.
finaly does anyone know when it will be available in the uk and howmuch it will cost
Basically it's:
GSM/EDGE/GPRS 850/1800/1900 MHz
So it's more the cingular wireless (since they now own att who deployed 850 in detroit IIRC) model. T-Mo said they weren't going to carry it, they might later, but that's what I was told a month ago. As they just bought up the western cingular network and the US carriers are diddling consumers by not having any decent sharing agreement in place I'd say it's only worth it if you're going to be in an 850 area.
For reference the 6600 is
GSM/GPRS/HSCSD 900/1800/1900 MHz
you get better service options in different countries, but you trade of EDGE w/ GPRS and stereo. If you get cingulars unlimitted datarate it's a good phone.
JasonT wrote:
Basically it's:
T-Mobile had plans to carry it worldwide but it is likely that they go for the 6630
(continued)
(continued 2) The 6620 would have been a good choice a few months ago but with the 6630 nearing release it is unlikely to reach the shops in any appreciable numbers
(continued 3 ) The 6630 betters on the 6620 in several respects :
(continued 4)
UMTS Shade thinner Much better ergonomics Megapixel camera Card hotswap
In the design they have put ergonomics before aesthetics so it may look a bit duff compared to the 6620 , but otherwise it is perfectly OK
