Bluetooth shortcut codes???
1 replies · 1,786 views · Started 13 July 2004
Hi!
Are there any shortcut codes to active the bluetooth on a Nokia 6600???
I cant just my joystick its broken... :frown:
VenoM wrote:Hi!
A way of creating a shortcut in the menu,is by moving the icon into the first page,then pressing the corresponding number (my icon is in the middle at the bottom of the menu page,so it is in position 8)
So in my case it is Menu/8/options/change,but if the joystick isnt working at all you will still not be able to perform this operation.
