Aqua calendar issues
11 replies · 2,880 views · Started 14 July 2004
hi,
is anyone using the full version of this? im running the demo at the mo, and while i think it will do what i want (enter tasks in FC mode), it keeps crashing/stopping! 😞
ta
It doesn't crash on mine! Are you using the latest version? (V. 2.3 build 2)
Do you have any other programs set to launch on the press of the Internet Button? Handy Day, Tracker etc.?
Is this flip closed or flip open?
its in FC mode. i do have key mapper and HD04 running. but they are set not to trap this key in FC mode. i even un-installed key mapper, and still no joy. it seems to work fine in FO mode, but i only want to use it in FC mode 😞
I'm not sure the shortcut key for aquacalendar works in flip closed mode. In fact, I'm not sure either of those two keys (camera and internet) can be re-mapped in flip closed. Have you tried handy keymapper. If that doesn't do it, it's basically not possible.
yep, key mapper can do it. i got it mainly to prevent the camera and internet launch by accident. Aqua manages to get the key occasionally, but it isnt reliable.
ah, good idea....but, i think you have summed up the p900/UIQ in one sentence there! it could all be a bit more open. in theory, yes i should be able to do this, but unfortunately Aqua isnt listed in the key mappers apps list. if i remember rightly it only lists SE stuff and not third party. havent got it installed at mo so cant check that for sure
Aqua cal is great! 😊
its top for banging in quick task in FC mode. the latest version has some good bug fixes in for the month view. nice one pockettorch
