My 9210 needs maintenance
1 replies · 1,787 views · Started 14 July 2004
Hello,
My 9210 is 2 1/2 years old and starts to show signs of weakness.
There are intermittent problems with the keyboard, which I can
solve by tightening the screws from time to time.
Since a couple of days it suddenly fails to find the network:
goes from best reception (4 strokes) to none 😞
If I try to move it, or do open/close or on/off it reconnects for
a while and disconnects a few moments later.
This is not a network problem, as there are other phones working
perfectly all around.
What can I do? Is there a maintance guide available? I have searched
this forum and Google and I haven't found a discussion of
this problem.
I don't want to bring it to the shop as the guys there didn't do
a great job last time I needed a software update. I'm pretty
sure that it would cost me a lot of money and that they are not
quite competent to fix such an intermittent failure...
Thanks,
Pierrant
You need to strip the phone down and put it back together again a as with time things come loose, if you pm me or give me a mail address that can take 5meg I have the nokia service manual which will help you.
