i just got my nokia 7610, when i tried to connect to the web it said 'GPRS: GPRS not available - check network services'... my phone is on contract with 02 and I tried to download the GPRS settings for it from 02.co.uk but they didnt seem to have them for the nokia7610... i tried getting the settings from different phones but it still just said 'GPRS: GPRS not available - check network services'... ive spent money on a coupla games but i cant get em cos i cant get onto the web to download them... its REALLY annoying! could anyone help at all??
-josh :frown:
I think O2 were having problems this afternoon because both me and my mate couldnt get GPRS to work when it is normally fine.
I think its ok now so if it still doesnt work maybe you need to contact them and make sure GPRS is enabled on your account.
its still not working... i think i'd better contact them... ah well :frown:
i had exactly the same problem. o2 couldnt fix it after a few expensive phonecalls to them (knew i should of stuck to orange!) all you have to do is go to the nokia site type 'WAP SETTINGS' in the search site and it has a setup wizard thing. worked fine for me for MMS and GPRS.
I used the wizard that was on the phone and it grabbed the setting automatically.
You can get the wizard from the nokia support pages if it's not already installed on your phone.
http://www.nokia.com/nokia/0,6771,59207,00.html
Best
WIll
