Birthday in the calandar
5 replies · 3,358 views · Started 14 July 2004
hoi folks
i was just adding some birthdays in form of a detail in the adressbook
but i had to remark that they are not automatically added as calandar events ...
so how to get rid of that problem if i don�t just want to add all the birthdays twice ( in the adressbook and in the calendar)
If you want them to be added in Contacts and Calendar, use the program called "Smart Birthday". Much better ...
nk_au wrote:If you want them to be added in Contacts and Calendar, use the program called "Smart Birthday". Much better ...
well i tried but i cant find a version that works with my 7610 .. can you help me out and send me the file ?
jep i installed the wrong version .. thx 4 link!
so by the way : do you know any realy good 3d games for 7610 ?
I just wanna see what this thing is able to do...
