CSV Import of Addresses to the P900
4 replies · 2,078 views · Started 14 July 2004
Hi Friends
Does anybody know how to import CSV-Address-Lists to the Sony Ericsson P900 (Symbian OS) Smart Phone?
We have weather Lotus nor MsOutlook available, but a lot of adresses in CSV (comma separated values).
Your best bet might be to search the Internet and see if you can find a utility that converts CSV's to VCards. The P900 will accept Vcards.
Other than that, I'd duggest you get hold of a copy of Lotus Organizer (even if it's only temporarily), import the CSV to that and then synch with the P900.
I have found some cool tool for linux to convert my CSV to VCards.
Now I have the next question: How can I import VCards into the P900 (Sony Ericsson Symbian OS Mobile Phone)?
The help only mentions Lotus and Outlook.
Any Idea?
Any way you want really. It should detect that it's a Vcard and ask if you want to add the contact to your contacts list. Bluetooth, infra red, the PC Suite, e-mail it to yourself, stick 'em on a web server and download them.
I take it from the above you're on Linux so you can forget the PC Suite. Bluetooth should work, depending on your flavour of Linux. I'd probably just e-mail the VCards to whatever e-mail account you have set up for the P900 to access.
