hi, I need some help with my Ngage (not QD if that makes a difference when it comes to sorting out the problem.) I had installed YEWNES (nes emulator) to my phone, while I was doing this my phone said "SYSTEM ERROR" then automatically exited the installation :? . The logo then apeared on the menu screen (though the YEWNES does'nt work. 😡 ) After attempting to use YEWNES I decided to delete it (off of my device memory not my MMC as that was what I had it saved to) but every time I used manager to delete the emulator it said "SYSTEM ERROR" (I've repeatedly tryed this but it ends up with the same outcome everytime). If anyone could help out I would be SOOO grateful. Thanks in advance.
Please Help Me !!!!!
I don't sure for this problem cause am a newer for Symbian but i think u can use another program such as SeleQ to delete its folder manually.The path of the program should be in c:\system\apps\Yewnes (something like this).Hope this can help u.
