troubles with MMC
6 replies · 2,803 views · Started 15 July 2004
Hello. I have a problem with my 3650, i hope someone who had the same problem could help me. I formatted the phone, but did not format the memmory card. Now when i input the memmory card all programs (menu, log, phone book...) could not run, and i get the message "system error". When i take out the MMC, everything is normal (exept 4 MB memmory😊. How can i format the MMC with some code? or how can i repair that??
martin389 wrote:Hello. I have a problem with my 3650, i hope someone who had the same problem could help me. I formatted the phone, but did not format the memmory card. Now when i input the memmory card all programs (menu, log, phone book...) could not run, and i get the message "system error". When i take out the MMC, everything is normal (exept 4 MB memmory😊. How can i format the MMC with some code? or how can i repair that??
Search the forum on how to format the mMC! 😡
it usually happens when you have installed an application and it starts running in the background and does some kinda sh*t, once it happened to me and i had taken it to Nokia Care. The idiots there gave up saying that the MMC is corrupt and can not be repaired.
Later i repaired it myself. it is working fine now without any problems whatsoever.
here is the procedure:
Restart your cel, keep the pencil button (on the left side of n3650 for example) pressed until the phone completely boots (it is called as 'safe mode'😉.
then delete all the files manually on your MMC using FExplorer or SeleQ. Then format the MMC using the Memory utility in Extras folder of Menu.
That'll do the thing.
Then restart your phone, it'll be up and running!
~: peace :~
maxdiamond
!�!�!�!�!� Symbian Rulez !�!�!�!�!�!�
"Restart your cel, keep the pencil button (on the left side of n3650 for example) pressed until the phone completely boots (it is called as 'safe mode'😉."
I did that, but the phone starts normal (no safe mode)?
Oh, it's OK now, the phone started in safe mode. Thanks maxdiamond i owe you.. 🙄 😃 :tongue:
ty for this tip. too bad i already bought another 128MB before reading this post. anyone wants to buy 16MB mmc?
first remove your mmc card to your phone. and then your mmc card insert to memory card reader if you have. Then format your mmc card to memory card reader. If finish the mmc card try to back, to your phone, and then format it again the mmc card thru phone.
