Problem syncing 6600 contacts with Outlook
1 replies · 3,710 views · Started 15 July 2004
Hi
When I use Nokia's PC suite to sync my 6600 contacts, there's no way to specify private/public, as there is with calendar items.
As a result, the contacts I create on my phone end up in my outlook folder as public. This is an issue as my outlook folder is shared with the rest of my team at work.
=> I need to be able to sync all outlook contacts with my phone, but distinguish between private and public contacts in the same folder.
I'd be grateful for any advice/alternatives.
PC Suite can't handle that, and I don't know of any other synchronization app that'd do it.
However, you could disable PC Suite contacts synch, and save the contacts as vCard or CSV files and use an app like Contacts Manager or SmartVCard.
