WHen i start up my phone it says Application Startup Closed before it fully starts up. My menu button is now no longer working but the button at the top right(contacts) and top left (camera) still work. Is there any quick fix for this. ALso my phone is running really slow.
3650 application problem
Unregistered12 wrote:WHen i start up my phone it says Application Startup Closed before it fully starts up. My menu button is now no longer working but the button at the top right(contacts) and top left (camera) still work. Is there any quick fix for this. ALso my phone is running really slow.
What apps have u installed lately before it had that problem?
If ever you would like to try uninstalling them first before doing a format, do a safe mode start, HOld pencil key down, then try if you could uninstall the culprit program.
Just do this .Reboot ur phone in safe mode by ..
hold the pencil key from the begining when the phone starts and it completes ,so i am sure u will not see the application error and also ur menu will also work fine ,next remove the bugging application from the phone and everything should be fine
deepak_vs24 wrote:Just do this .Reboot ur phone in safe mode by ..
Isnt that what I just said?
