Hi
I have just got my p900 phone and was wanting to use my Plantronics headset M3000. This headset worked fine with my t68 and still does but the p900 fails to recognise it. I have checked on the SE site and followed all the instrutions on how to pair a headset still no luck.
Can anyone help me. The phone is on orange.
Thanks Loads in advance
Nadeem
Just so you know that headset works fine with the P900 as I am using it OK. I just followed the instructions that came with the Plantronics and it worked! Don't forget the pin number 0000.
Cheers
Dave
Will try again but mine does not seam to discover headset so can't proceed any further will keep posted if work or not.
Thanks Nadeem
The phone and handset work fine i have them fully functional now
That's good news! Can you tell us what the problem was?
