Nokia 7610 MMC Card Wiping
2 replies · 2,407 views · Started 16 July 2004
i have installed some games on my rs-mmc card and want to remove them.
Is there anyway from the phone or via the pc suite that i can do this?
I have tried browsing the phone through explorer but the installed apps dont show up.
Thanks.
Mr MMC wrote:i have installed some games on my rs-mmc card and want to remove them.
Thanks.
Yup, if they don't show up in the Uninstall program, you can install FXplorer, and through that you can delete the programs.... - If you installed java apps, they will be in e:\system\apps\ and then called something like 6R45...- something like that...
