Problems!
2 replies · 1,089 views · Started 16 July 2004
Hi ppl
A couple of questions if you don't mind.
1.When i try to drag and drop files to my MMC i'm getting the message 'disc is write protected,remove write protection or use another disc'......any ideas,i never used to have any problems,i've used 2 different MMC'S one of which already has loads of stuff on it but i'm getting the same message for both?
Also what's the best method for putting ir remote and ultra mp3 onto a 6600,do you send them to the fone or the MMC
Cheers
T.
i presume ur using a card reader;have u tried going into properties in windws exloreer and unchecking the read only box also try cuttng(ctrl+c)and pastin(ctrl
+v)
the best way to sed progs to the fone is to use blue tooth then they wil appear in your inbox nd you will be able to access the instaler much easier
hello from athens,
i bought a 16in1 digitus card reader and i have the same problem. have you understand what is going on? have you find a solution? i think that something does the phone to mmc. Please tell me if you found something
thanks a lot :tongue: :tongue: 😊 😊
