sorry about these 😊
1.how do you enter a return character in FC mode
2.how do you select a word from the word list without adding a space
-the manual says use 'ok', but that adds a space still
3.can you setup/add text modules/templates
sorry about these 😊
I'm sorry, don't know the answer to any of these questions BUT I would be very interested to know the answer to the first question.
When I use the notepad in FC mode and I want to go to the next line I always have to disable t9 first. Is there anyone who knows how to do this with t9 activated??
DAN55 wrote:sorry about these 😊1.how do you enter a return character in FC mode
If you navigate to the correct suggestion with the jog dial so it is highlit, instead of pressing anything, just hit the # key (for a space) and it will automatically insert that word. Is that the right answer? 😮
sorry, no, it still puts a space in
Would there be anything wrong with just simply hitting the 'C' button to delete the automatically generated 'space' ..?
e.g. to "create" 'houseboat' press "4 6 8 7 3", # or 'OK', 'C', "2628"
Regards ...
