HELP. I have 2 memory cards for my phone and can't access them because the phone reads them as corrupt. How do I fix this problem. I need the cards to work and can't do anything with them. HELP
A925 Memory card corrupt report on Phone.
Try formmating them in the phone !! if that does not work format them in a computer first !!!
Have tried to format on phone and also renaming on phone.
Format reports that card needs to be formatted first and locks me out.
Renaming the card gives me a card corupt warning and locks me out.
Have to try on a computer, apart from that I am stumped as to what to do next.
What happens if the computer can't help me fix the problem? Take the phone back and get them to sort it out?That would be the second time and the second handset that I have had. Please help a poor bastard like me that always gets the rough end of the stick.
david_correia wrote:Have tried to format on phone and also renaming on phone.
I highly recommend this shop and thier swift service and for the sake of �6 I suggest you buy it !!! it will make transfers to you SD card fast and easy as opposed to pain stakingly slow, which it is via the USB cable to the phone (the phone has issues and does not do proper USB speed transfers)
What size and make of cards are they? :?
The cards are the 3 cards from 3 and are both 32mb. Have tried to format on PC and still nothing. AAAAAAAAAAAAAAHHHHHHHHHHHH. Gives me the Poo's. Have to take the phone back, maybe a firmware problem. 2nd time taking phone back to get looked at. First time I got IR activated and they said the phone was faulty because it would not accept the upgrade and had it replaced. Now will take this one back to see what they say.
After formatting them in the PC did they then work in the PC ????
david_correia wrote:HELP. I have 2 memory cards for my phone and can't access them because the phone reads them as corrupt. How do I fix this problem. I need the cards to work and can't do anything with them. HELP
i had the same problem call three care if it is a 3 SD card
they will peplace it
if under waranty
