bluetooth file transfer..
1 replies · 1,969 views · Started 17 July 2004
hello, im new here:P
i use widcomm to transfer files from my pc to my nokia 6600 but i dont know how to transfer files from the phone to the pc. is that possible using widcomm?
Yes,
Just go to the file select send>bluetooth, you will get a choice of the most recent device or to search, find your pc, select it and click send. By default you hear a silly windows noise and your file should be in the bluetooth exchange folder on your machine. If you have problems run the widcom util and add the obex (IIRC) protocols for your phone and pc.
