Real Player
11 replies · 4,260 views · Started 17 July 2004
crckr wrote:How do i make my real player in a full screen mode
They both have trial versions.Why don't you see for yourself.BTW: 16.99 is the cost of the player only.You can add additional 59.99 for the converter.If you buy SmartMovie,for the price of 24.99 you get a converter and player.
Advantages?SmartMovie is using an open video standard - XVID which enables you to encode your videos with standard and powerful video encoders like VirtualDub while PvAuthor is flaky,bugy and crashes a lot.The picture and playback quality of SmartMovie IMO is a lot better,although you need to struggle a bit to get perfect A/V sync.
GhostDog wrote:They both have trial versions.Why don't you see for yourself.BTW: 16.99 is the cost of the player only.You can add additional 59.99 for the converter.If you buy SmartMovie,for the price of 24.99 you get a converter and player.
Hail Smart Movie!!! 😃
....very easy.....don�t use RealOne but the onbard Videorecorder=>Options=>Select Video=>while playing....type a Numberkey=>enjoy FULL SCREEN VIDEO!!!!!
MFG Softseeker
willbrady wrote:Next version of realone will have fullscreen option - keep your eyes on www.real.com for upgrade - not looked in a while, may even be there already.
Will 😊
Could u please give me the proper link i mean exact.
thanks very much
Hi i hav 2 ques
is smart movie play 3gp.
and other is which should i slect in VIDEO CODEC CONFIGRATION
there are intel 5.10 and many microsoft
wht is this
wht u shoudl i slect
