quickoffice - quicksheet
5 replies · 3,920 views · Started 18 July 2004
does anyone use quicksheet full version?
i got the trial version and it doesnt save the changes i make, ie when i open the xls in excel on my pc its just code. is this because its the trial version, or can you just not do this at all?
if i cant do this, is there any symbian apps that will let me do this?if not....who wants to buy my p900?!
cheers,
t
What version of Excel are you using on your PC?
If it's an older version, it might not be compatible with QuickSheet, in which case, you need to download a patch from the makers website.
Cheers bassey, but its excel 2000 im running.
Mailed the makers of QO and they havent even got back to me yet.....1 week on!!
Is there any other software out there that lets me edit xls and export?
Cheers
T
Yeah, I believe there is a Visual Basic program that lets you do it, but you need to have Appforge Booster installed in order to run that. It's entirely up to you, but personally I won't install Appforge booster on my phone.
It might be worth uninstalling Quick Office and reinstalling it. I've found no problems copying over spreadsheets in different versions (Office 97 and XP). I have more problems with the Quick Word, but as it's QuickSheet I use most, I'm not that bothered. I believe there was also an earlier version of QuickOffice that was a bit dodgy. Make sure you have the latest (I think there is a utility on the file menu to check for an uptodate version).
Hi! new here, i have used the full version of quick office and it works fine.. i think you'll just have to have the full version..
cheers!
jbourne
jbourne wrote:Hi! new here, i have used the full version of quick office and it works fine.. i think you'll just have to have the full version..
cheers!
jbourne
Where did you get the full version? Can you send me a private message on this?
