other ways to tranfer files to & from the pc aside from usb
3 replies · 2,854 views · Started 19 July 2004
hey! my usb doesnt seem to work.
is it possible for me to transfer files (like software and movies/songs, files, themes, etc.) by transferring it with my card reader?
--- will it be able to install on my phone straight from my rs mmc?😊
coz the whole cd that came along with my 7610 wont install on my pc. 😞
Try downloading th new pc suit from nokia, the one the ships I think is already out of date. Also Are you using win xp with SP1? You need win xp with SP1 to run the pc suit.
Using a card reader would be fine except that everytime you wanted to install stuff you would have to turn the phone off, pull of case, battery and then remove card and thats kinda annoying.
thanks!😊 i was already able to install the pc suite and others, though everytime i try to back my phone up it always says "lost connection"
any tips?
